Ignition issue?
MontanaSkiRaptor
WA and MT
Ok, I'm wondering if this is a problem or not. When I have my key in the ignition it doesn't do the door chime most of the time when the door is open and ignition off. I've had it do what I would call the normal key in the ignition warning when leaving the keys in the ignition and getting out maybe 3 times, otherwise it doesn't make a peep. If I push the key in it will ding once and light up the needles and the odometer. Also does the same thing if I turn it just a little, so there is a little play. I'm used to other vehicles giving you the warning dings that your keys are in the ignition but this is the first issue I've had with a vehicle doing or not doing this. Anybody else have this issue?
