How to pull 15 inch of travel on a budget.
NateMob
SATX
Did you measure your travel numbers?
Not my truck and i doubt the owner did either.
I guess the 90° drill attachment is key. Thanks for the tip. Is the weld-on version the same as the bolt- on one? Do you use the holes meant for bolts to do rosette welds?
My guess is they are the exact same minus the pretty powdercoat. I would run beads around the perimeter of the bracket for the most strength and factory look and probably do the rosettes just cause.
