How do you turn off AUTOLOCK?
Rango
So I found this on the net and tried both with no luck:
Put the key in the ignition and turn it to on.
Press the Unlock button three times.
Turn the ignition off.
Press the Unlock button three more times.
Turn the ignition back to on.
The horn should beep once. This tells you that you’re now in programming mode.
Press the Unlock button, then press Lock again. The horn will beep once to tell you that Auto Lock was deactivated. It will beep twice if you’re reactivating the system.
Turn the ignition back to off and listen for the horn to beep one time confirming that the programming was accepted.
If your vehicle has the keyless entry pad on the driver’s door you can use this procedure.
Key off, out of the ignition and al the door closed
Enter the factory 5 digit code.]
Press the 3.4 button and hold.
Press and release the 7.8 button while still holding 3.4 button
Press 7-8 again while still holding the 3.4 button
Release the 3.4 button
The horn should sound once to indicate disable or twice for enabled
Any idea how to do it on our trucks without FORSCAN? :biggrin:
NASSTY
ME
I don't know if it's different on the fancy schmancy trim levels or not? But on my plain jane 800A I can shut them off on the info screen on the gauge cluster.
Click on Menu
Click on Settings
Click on Advanced Settings
Click on Vehicle
Click on Locks
Uncheck Autolocks
kandewinn
Bump on This
Click on Menu
Click on Settings
Click on Vehicle
Click on Locks
Uncheck Autolocks
Same for my "Basic" 801a, LMAO!!!! I must not have the right gizmo to make it a real PITA.
