- Joined
- Jul 15, 2017
- Posts
- 1,052
- Reaction score
- 958
We developed our Plug N Play Wire Harness System about 2 years ago. It was introduced on the Motor Trend Channel in Spring of 2021.
It was so unique, we filed a patent on it. The Patent is in its final stages to be finalized, however, the products are available now.
What makes it so special? Well. The problem most consumers have when installing their lights are understanding the wiring and the manual customization required to splice, and integrate wires to combine lights, add or remove relays and even access factory features like reverse light triggers, Tail Lights, Marker Lights, Parking Lights ETC.
Many will tell you to use a "Fuse Tap". We have Plug In components to add to your headlights, or tail lights with factory connectors that simply plug in to the vehicle and plug into any of our harnesses.
Much like a Lego Set. You can simply pick out pieces and plug them in to accomplish whatever you want. This includes full length harnesses for rear lights that go to switches alone. Or, you can plug in our tail light adapters for automatic reverse triggers for reverse and backlights with the tail/parking light circuit. Or, you can get our short harness to the lights only and our tail light adapter. All of our tail light adapters have built in diodes so there is no back feed to your tail lights.
Each harness comes with a common 3 port connector that can be used with included connectors for lights with bare wires or plugged into our matching adapters to plug into any light model or brand.
We released these kits with popular lights a long time ago. So there are kits for Diode Dynamics, Rigid and Baja Designs. Our Brackets are also universal and can be moved anywhere under the rear bumper. Not just the outer sides. We just think they look better spread out. You can also put them center on each side of the hitch. However, our harness system can be used with any lights. Including FLUSH MOUNTS should you prefer those.
Here are some links to the plug n play rear kits-
Our Fog Kits ALSO utilize our Plug N Play Harness System. Lights with Backlights, like the Rigid Radiance Or Diode Dynamics can utilize our Plug In Headlight Adapter for backlights with the Parking/Marker Lights. While the Diode Dynamics wiring with their Fog kit is complex and confusing. Ours just plugs in. You can connect each light pair to a separate 3 switches. Or you can add our 2 or 3 way splitters at the switch wire ends and plug n play combine them. No twisting wires together. If you ever want to separate them again. You can unplug and rearrange them.
Here are Some of our Fog Kits-
Our A-Pillar Kits are the Same way. If you have backlights, you can use our headlight adapter. You can even share those backlights with our plug n play splitters to multiple lights and light bars with our various harnesses.
Here is one of our A-Pillar Kits-
We also developed mounting solutions for the Stock Bumper to hold any 40" Curved light bar, including the Full Size Rigid E-Series or Radiance..
Here are some examples-
When I was talking about splitters and relays that can be added on. Here are some links to those for reference. Our 2 and 3 way splitters can be added to the ends of harnesses to combine them to single switches, or to split connections to backlights from factory marker/headlight/tail light adapters-
Our Light END Splitters can plug into the end of our harnesses to split the end to add 2 or more lights instead of one-
Our Harness End Light Adapters can plug into any of our harness to match any light model or brand (Can be selected with harnesses as a kit too)
Our Relay adapter can plug into any of our harnesses should you need a relay for some extra juice if your AUX switch can't handle it.
Of course we talked about tail light adapters and headlight adapters, but here they are-
We also created some additional kits like our numbered switch wire extensions that you can add to your switch wires for numbered 1-6 wires with connectors to plug right into our harnesses as well as a prep pack that you can add to all wires and pass throughs in your Bronco/Raptor-
Then we have Light bar Harnesses, Fog Light, A-Pillar and Rear Harnesses that can all plug n play and interconnect to any components in the system-
For a basic demonstration of the system. Here is a video clip from its introduction on Motor Trend in Spring of 2021-
Here are some more videos on some of these kits, harnesses and installs-
There is some renewed interest in hitch lights as well. We developed our Hitch light kits for these trucks in 2017. Currently we offer them in the Full Size Rigid D-Series or Baja Squadron. Here is a video and links.
The idea is that these are inexpensive and require no "Installation". You plug them into the 7 pin. You can LOCK them with a hitch lock, and you can remove them when you want to use a trailer...
We would love to hear from you. If anyone has questions, or comments or ideas they would like to discuss. Please reach out to us!
info @spvparts.com
317/934/6778
John
SPV Parts 2017-2020 FORD F-150 RAPTOR RIGID REAR SR-L SERIES REVERSE LIGHT KIT (NO DRILL) SRL rear light kit
Purchase new Rigid reverse lights for your 2017-2020 Ford Raptor at Specialty Performance Parts! Our light kit comes with your choice of harness.
specialtyperformanceparts.com
SPV Parts 2017-2020 Ford F-150 Raptor RED Rigid Radiance Reverse Light Kit Backup LED Kit (20202 & 68202)
Pick from the Rigid Industries Radiance, or Radiance Scene versions: The Standard Radiance and the Scene versions have the SAME effect. The Backlight (Amber or Red) is the same. The Differences are this- Radiance- 1 LED Per Pod (2 total) Scene – 4 LED’s Per Pod (8 Total) Radiance Lumens – 900...
SPV Parts 2021-2024 Ford F-150 Raptor Rear Diode Dynamics SS2 Series Reverse Light Kit (No Drill) Red Backlight Rear LED
NEW! The new SPV Raptor Reverse Light kit utilizing the Diode Dynamics SSC2 Series lights are here!! Similar to the Radiance series, these DD new lights have a Red backlight when off and a powerful white backup light when on. The advantage to these is the slimmer case with a 2 series led. If...
SPV Parts 2017-2020 FORD RAPTOR - REAR BAJA DESIGNS S1 / SPV REVERSE LIGHT KIT (NO DRILL/MOD) rear light kit (Gen 2)
NEW! SPV Parts 2017-2020 FORD RAPTOR - REAR BAJA DESIGNS S1 / SPV REVERSE LIGHT KIT (NO DRILL/MOD) rear light kit (Gen 2) The New SPV Raptor Reverse Light kit utilizing the Baja Designs S1 lights are Here!! The advantage to these is the extra slim case. If you want similar light output and less...
SPV Parts 2017-2020 FORD RAPTOR - REAR BAJA DESIGNS S2 / SPV REVERSE LIGHT KIT (NO DRILL/MOD) rear light kit
NEW! SPV Parts 2017-2020 FORD RAPTOR - REAR BAJA DESIGNS S2 / SPV REVERSE LIGHT KIT (NO DRILL/MOD) rear light kit The New SPV Raptor Reverse Light kit utilizing the Baja Designs S2 lights are Here!! The advantage to these is the extra slim case. If you want similar light output and less bulk...
SPECIAL BUY - SPV Parts 2017-2020 Ford F-150 Raptor - Rigid Radiance/Scene Fog Amber LED Triple Fog Light Kit Including Brackets (20204 & 68204)
Purchase a new set of amber LED fog lights for your 2017, 2018, 2019, 2020 Ford Raptor online at Specialty Performance Parts! These lights come with mount brackets.
SPV Parts 2017-2020 Ford F-150 Raptor Rigid PRO Triple Fog Light KIT
Purchase a Rigid Pro fog light kit for your 2017-2019 Ford Raptor online at Specialty Performance Parts! This kit comes with your choice of light combinations.
SPV Parts 2017-2020 Ford Raptor Baja Designs Sport & PRO Fog Light Kits (With Brackets)
Customize your Raptor with an SPV Pro Fog Light kit! This kit includes a pre-configured Baja Designs pro or sport light selection, and our custom SPV fog brackets that we specially designed that offer more adjustability than ANY other fog brackets on the market! This kit is sure to give your...
SPV Parts 2017-2020 Ford Raptor Diode Dynamics Sport & PRO Fog Light Kit (With Brackets & Harness)
Customize your Raptor with an SPV Pro Fog Light kit! This kit includes a pre-configured Diode Dynamics pro or sport light selection, and our custom SPV fog brackets that we specially designed that offer more adjustability than ANY other fog brackets on the market! This kit is sure to give your...
Specialty Performance Parts A-Pillar (Ditch) Light Kit for Ford 2017-2020 Raptor/2015-2020 F-150
Purchase our A-pillar light kit for your 2017-2020 Raptor or 2015-2020 F-150 online today! This kit comes with your choice of Rigid lights and a custom harness.
SPV Parts 2017-2020 Ford F-150 Raptor NO DRILL Bumper Mount & Rigid 40'' Curved Light Bar Kit
Purchase a 40" light bar kit for your 2017-2020 Raptor at Specialty Performance Parts! This light kit comes with a no-drill mount for quick installation.
SPV Parts Harness 2-way Splitter or 3-way Splitter (Single Pole) - SPV Harness System (Works with MANY vehicles, See Details)
2 Way/3 Way Splitter Adapters MAIN APPLICATION/DESCRIPTION- Use these splitters for the following applications with our universal harness system- 2 Way Splitter - Use to combine a pair of wires or split a pair of wires 3 Way Splitter - Use to combine or split 3 sets of wires Examples would be-...
SPV Parts 2 Way HARNESS Splitter with 3 Pole WP Connectors (Single) - SPV Harness System (Works with MANY vehicles, See Details)
2017-2019 Raptor Custom fog harness for Rigid Industries D-Series Pro fog lights! Don't worry about messing with the wiring yourself, let us do it for you! Pick up your fog harness and join the SPV family today!
2 Pole DT Connector HARNESS Splitter (Works with 2021- 2022 Raptor OEM FOG Connector Adapters & Others) (Sold in Singles)
2 DT Connector Splitter MAIN APPLICATION/DESCRIPTION- Connects to any 2 way DT connector and splits it to connect 2 lights. Also used in the factory fog connection in the Gen 3 Raptor to split 2 lights on one connection with our factory fog adapters. Plugs directly into an aftermarket light. The...
2 Pole Weather Pack HARNESS Connector Splitter (Works with 2021- 2024 Raptor OEM FOG Connector Adapters & Others) (Sold in Singles)
2 Weather Pack Connector Splitter MAIN APPLICATION/DESCRIPTION- Connects to any 2 way Weather Pack connector and splits it to connect 2 lights. Also used in the factory fog connection in the Gen 3 Raptor to split 2 lights on one connection with our factory fog adapters. Plugs directly into an...
SPV Parts Harness 4 Pole DT Connector Adapters (Single) - SPV Harness System (Works with MANY vehicles, See Details)
4 Way DT Connector Adaptor (To Universal Harness System) (3 Wires for Diode Dynamics lights WITH Backlights) MAIN APPLICATION/DESCRIPTION- Works with Various Series Lights that use the square DT 4 Way connectors, and connects to the SPV Universal Harness System. Typically Diode Dynamics. These...
SPV Parts Harness 2 Pole DT Connector Adapters (Single) - SPV Harness System (Works with MANY vehicles, See Details)
2 Way DT Connector Adaptor (To Universal Harness System) MAIN APPLICATION/DESCRIPTION- Works with Various Series Lights that use the 2 way DT connectors. Typically Rigid Industries Pro Series as well as others. Harness System Description- This harness is part of our UNIVERSAL harness system...
SPV Parts Harness 2 Pole WP Connector Adapters (Single) - SPV Harness System (Works with MANY vehicles, See Details)
2 Way WP Connector Adaptor (To Universal Harness System) MAIN APPLICATION/DESCRIPTION- Works with Various Series Lights that use the 2 way Weather Pack connectors. Typically Baja Designs Pro/Sport/Racer Series Single Stage (Not backlit) lights as well as others.
SPV Parts Harness 3 Pole DT Connector Adapters (Single) - SPV Harness System (Works with MANY vehicles, See Details)
3 Way DT Connector Adaptor (To Universal Harness System) MAIN APPLICATION/DESCRIPTION- Works with Various Series Lights that use the triangular DT 3 Way connectors, and connects to the SPV Universal Harness System. Typically Rigid Light Bars. Harness System Description- This harness is part of...
SPV Parts Harness RELAY/FUSE Add on Adapter - SPV Harness System (Works with MANY vehicles, See Details)
Relay and Fuse Add on Adaptor (To Universal Harness System) MAIN APPLICATION/DESCRIPTION- Works with ALL of our Universal Harness System Harnesses. If you need to add a fuse and relay to an application because you either don't have built in relays/fuses in a factory switch panel like the Raptor...
SPV Parts Harness Taillight Connector Adapter (Powers Reverse Lights/Backlights) - SPV Harness System (Works with MANY vehicles, See Details)
Tail Light Adapters MAIN APPLICATION/DESCRIPTION- These add on adapters connect to the factory tail lights of MOST vehicles. (More makes/models coming soon) You simply plug the adapter into your tail light, and the factory harness into it. The other end connects to our FULL LENGTH Rear Harness...
SPV Parts Harness System - Raptor Parking/Marker Light Connector Adapter (Powers Aftermarket Backlights w/ Parking/Markers) (Works w/ MANY vehicles)
Raptor Backlight/Marker Light Adapters (Watch the video) MAIN APPLICATION/DESCRIPTION- These add on adapters connect to the factory harness under the plastic radiator cover. It simply plugs in between the factory harness and then connects to any of our Universal harnesses. This allows seamless...
Auxiliary (Aux) Switch Wire Extension Kit with Connectors (Numbered)
SPV Parts is proud to present our new Aux Switch Wire Extension Kit. This new kit will extend your Aux switch wires in your Raptor, Bronco, Super Duty, Tremor and other vehicles by about 8 inches. In addition, each includes a single Weather Pack connector installed for quick connect to any of...
SPV Parts Ford Bronco, F-150 Raptor, Tremor, Ranger Aux Wire Connector Prep Kit (Includes 16 connector kits))
Connector Kit for vehicles with Auxiliary Switches- Bronco/Raptor All Generation F-150 Raptors Tremor Ranger Tremor/Raptor Super Duty Jeep Others Each kit includes Male and Female Connectors as well as pins and plugs for your switch wires and pass throughs Our new harness system utilizes...
Search: 85 results found for "spv harness system"
At Specialty Performance Parts, we carry only the best quality Ford performance parts. For Ford F-150, Ford Raptor, & other auto brands & deals, shop SPV parts.
SPV Parts Universal Hitch Reverse Light Kit - With Rigid Industries Flood Pod
Purchase our hitch reverse light for your Ford truck online at Specialty Performance Parts! This universal light plugs into your existing 7 pin plug.
SPV Parts Universal Hitch Reverse Light Kit - With Baja Designs Squadron Sport Wide Cornering
SPV Universal hitch light that fits ANY TRUCK MODEL! Just plug it into the hitch received and you're good to go! This offers you the simple plug and play design that you're looking for. When you don't want it, just take it out and store it for when you need it! No hassle, no stress, no cutting...
info @spvparts.com
317/934/6778
John
