GEN 2 AUX 5 FUSE KEEPS BLOWING
GabrielM619
san diego
I have a BD squadron chase light that draws 2amps wired to my AUX 5 ... but its been Blowing up the fuse and can't seem to figure out why... any suggestions will be much appreciate it!
Nex
RIP CoronaRaptor
Washington State
Welcome to FRF. Please post pictures of said prius with AUX 5 switch.
Which squadron are you running? The sports draw 2.2a EACH. So on initial turn on it might spike a bit more.
How do you have them wired? Where is the ground? Are you using the BD harness with the relay?
Sig Fanboy
WV
I guess I would ask if you are using a relay also. I have two Squadron R SAE yellow fogs on aux 6, same amp rating as aux 5, no issue.
G
GabrielM619
san diego
sorry i didn't was specific ...i have a 2020 ford raptor, running the baja designs squadron (only 1) on my auxiliary switches which is a 5A and will run for like 15 mins and then the fuse blows
Nex
RIP CoronaRaptor
Washington State
How do you have the lights wired? How are they grounded?
G
GabrielM619
san diego
1 single BD SQ SPORT on 14g wire, wired to AUX 5, grounded separately, from my other BD xl80s
Guessing wire might have a cut or something, checked my ground and seems fine ...
Nex
RIP CoronaRaptor
Washington State
Run the ground to a body ground, not to another light ground. And yes, also check to make sure the power wire didn't get pinched causing a short.
