GEN 1 Front camera shows rear
  • Start date
HORN HIGH ACES
Colorado
How did you fix it?
My camera had a rock chip in the lens so I got a new cam from tasca, except it was a couple months earlier assembly date (same part no).
Front and rear camera WERE working fine, but after replacing (and getting a new set of admin IKT keys w/ resetting the dash key count), now the front camera stays on while in reverse.
I had the exact same issue when I replaced my front camera. The dealer had to "reset the system" and then it worked fine.
While it was malfunctioning, the rear worked as expected when the front was disconnected so you may want to try that until you can get a permanent fix.
Smilodon
SW Utah
We just picked up a 2013 yesterday. In off road mode the camera shows the rear going in either direction. The back up camera works normally otherwise. Any ideas?
93,180
56,460
khunter
