Earned my stripes on first Raptor Run, recommendations
OEMPlus Raptor
OEM preferred....
Oxnard CA
So if anyone here follows the "Keep it Dirty" channel on YouTube. Helio recently had a run in the Lucerne Valley here in California. All in all, it was well organized and I had a blast.
However after washing the truck yesterday, I felt some rough areas in the paint and sure enough I some light gravel chipping towards the rear fender and lower doors. Do you guys recommend I run mud flaps in future runs or should I put on some Paint Protection Film on the lower panels. I even got some chipping on the door handles. That's about the only disappointing thing. I may have to color sand and buff out. Here are some pics for you all. Really loving this Raptor and using for what it was made for. I just like keeping my truck looking good as well.
Here are some pics!IMG_20200912_105953.jpg IMG-20200913-WA0001.jpg IMG-20200913-WA0010.jpg IMG-20200913-WA0017.jpg
Seattle wa
Yeah from experience I would recommend both. I have rally armor mud flaps and they are great. I went through a few sets before I found something that would take a beating.
xpel is expensive, but I had my 19 done right away this time. With the blue it just dings everything up. So the xpel is a self healing appliqué. It’s pretty trick and I recommend both the rally armor and the xpel.
Guy
Get the inch wider carbon fiber fender flares. You’re running an offset wheel and that is where the chips came from mostly.
CoronaRaptor
CANADA
I didn't like the look of mudflaps, so I went with 3m clear film on the bottom of both doors, It's held up very well for the last 5 years. I put it right over all the chips I had already amassed. They say it can yellow over the years exposed to the sun, but mine is garage kept mostly, so there hasn't been any of that going on. Nice group run btw, that looks like a blast. I went through some thorn bush's once and I managed to polish all but one out on my front fender, ended up having to wetsand it and polish. So protection is best if you can.
OEMPlus Raptor
OEMPlus Raptor
OEM preferred....
Oxnard CA
I was able to get quite a bit of with a microfiber cutting pad and compound. I have a few more sections to go and then I'm going to have PPF put from the body line down.
Sent from my IN2025 using Tapatalk
DansDrives
Snoqualmie, WA
+1 for Xpel and front flaps. They have been a must on every truck I've had. The Rally Armor are great because they can flex so much and you won't rip them off.
