Does rigid make a “shorter@ bracket?
chujk1985
Installing my rigid fogs with the diode dynamics mounting bracket.
Does anyone know if Rigid makes a “shorter” mounting bracket? When mounted the bumper is covering a small section of the bottom of the fog.
Uncas
Heading to Colorado
Same Issue with the D-SS, I talked to Rigid Support and they are passing it on to the engineers since I was the 10th call they have had about this. Email them and we'll see if we can get them moving faster.
https://www.rigidindustries.com/contact-us
C
chujk1985
Thanks for the info! I am seeing others mounted pretty flush with the bumper cut-out. It seems like there are some shorter brackets out there?
Uncas
Heading to Colorado
You find them, post it. I would love to pull mine up about 1/2 inch.
Uncas
Heading to Colorado
The more I look at the website, I think they changed up the bracket.
I would love this height........................................................... Which looks nothing like this.
C
chujk1985
I was thinking the same thing, but I couldnt be certain since the "shape" and "features" of the bracket look the same. I didnt know if it was just the photo that made it look different. I could not find any dimensions of the two.
Also, I was wondering if the bracket could be fitted going the opposite way. Instead of pointing the bracket towards the front of the light, point it towards the rear. I havent had the time to experiment, but it is probably unlikely that it would work.
---------- Post added at 11:39 AM ---------- Previous post was at 11:38 AM ----------
Did you flip the front housing to get the "Rigid" lettering right-side up?
Uncas
Heading to Colorado
1. I tried that, but it would not work.
2. Yes, don't tell Rigid.
downforce137
In Diana
two things..
1.i think your rigid brackets are on backwards..
2. can the diode brackets be on the wrong sides of the truck? I thought the bend was supposed to go up in the rear of the bracket/truck if that makes sense.
CROOKS
Spin the bracket around and mount the light as high as possible.
Rigid D2 fog, spot, flood on an L channel of aluminium.
C
chujk1985
oh, so it does work. Uncas up above was saying it would not work for him. I will give it a try.
93,180
56,460
khunter
