Coolant leak?
Raptor92
Hey everyone
After noticing a small /almost dry puddle of red liquid( most probably coolant) under the passenger side of the truck , crawled under and observed water droplets coming through the frame near the passenger wheel side.
It seems the leak stops after turning the engine off.
Used a spot light to trace the leak, but all hoses seam bone dry along with expansion tank filled to max line.
Any input is appreciated.
2018 gen 2
800 miles on the clock.
R
Raptor92
Will check with the local dealer since I couldn't locate the leak precisely .
Here is what I found.
R
Raptor92
Took it to the dealer
And all the sudden as usuall it stopped leaking
When back home , coolant dripping is visual again
K1llD4shN1n3
Colorado
I just upgraded my radiator and found it had been leaking. Full Race radiator is really nice!
FordTechOne
Detroit
There still would have been evidence of a leak path present with coolant residue...it's unacceptable that they gave it back to you without performing further diagnosis. Leaks are not intermittent; adding dye to the cooling system and pressure testing it would have revealed the leak without question. That is very poor customer service from that dealer; I would take it to a different dealer if possible.
