GEN 2 Battery Sensor Fault
nikhsub1
Los Angeles
So this didn’t trigger a CEL but I have a B1438-03 error. Anyone seen this before and know of a resolution?
FordTechOne
Detroit
DTC B1438:03 is “Battery Current Sensor - Frequency Modulated/Pulse Width Modulated Failure. Have you checked to make sure it’s plugged in and properly mounted? Also, if you clear the DTC does it return?
FordTechOne
Detroit
That was for a 2017, which explains why your truck doesn’t have one. Did you do any programming modifications with ForScan?
