Aux question
dudmleh522
AZ
Looks like aux 5 is rated for 5amp. I have pair or leds which is 40w each. Soon as i turned it on i think it blew the fuse. Is this too much light for switch 5?
rickysnickers
Idaho
Rough math says they are pulling about 7 amps, so probably yes probably pulling too much for that switch. However, someone else that is better with electrics will chime in as well.
dudmleh522
AZ
So what do you guys use for chase lights?
Which light? And whats the wattage?
Aux 1-4 and 6 is all taken for me
dudmleh522
AZ
thx for the info. or what would be the maximum wattage lights I need if I don't want to use relay?
goblues38
STL
5 amps x 14 volts - 70 watts (but you should not go above 50% rating for normal draw)
stop being cheap. if you don't know how to to it, pay someone to do it correct. you need a relay. PERIOD. It is not that hard.
