Another Raptor oil change solution
BIRDMAN
Birdministrator
Boston
This is the idea I am going to stick with. It's way quicker than removing the skid plate panel or the whole skid plate like others have suggested.
  • Drain oil
  • Put medium sized Tupperware container underneath the oil filter
  • Loosen the oil filter a few turns and let it dribble out in to the Tupperware
  • Once it stops draining just unscrew the oil filter and dump the rest in to the container
There's plenty of room to get the old filter and/or the Tupperware back out without spilling a drop! Just reach right down.
pirate air
will plunder your booty
I use the access panel, no mess, not even a drip:bleh:
Xjrguy
Anyone try using a topsider with the Raptor?
I have one in my garage and think I might try that next oil change.
Won't resolve the filter mess though.
warrior
Your Wife's Personal Trainer
for what it cost's, the dealer can deal with those issues.
BOJANGLES
<span style="color: red;"><b>Administrator</b></sp
Chihuahuan Desert (EPTX)
You're gonna end up with a face full of oil, Bird!
We wanna see pics of you dumping that Tupperware on your beak and then walking around like some product of the Exxon Valdez spill. :)
I think I'll be sticking to the access panel meself. It's quick and easy. Even removing the entire skid plate only takes like 4-5 minutes, but after trying the access panel I'm now sold on that method.
IRONMAN
Well-Known Member
MICHIGAN
I tried your tupperware idea and it wouldn't fit, how about a pic of this thing.
Did you cut it to fit cause I even tried a paper plate just to see if it would fit and
barely fit.
I just laid a rag under it and took it off fast.
BentToast
Namby-Pamby Land
barely fit.
Try a watter bottle, you shouldnt need any cutting to make this little baby fit
:naughty:
