ADD Pro vs. SVC Baja Bolt On Comparison
Pure745
Orange County
Here you go:
As close to side by side as I can get. Long story short I had the ADD Pro Bolt On for about 3 weeks before having SVC do my truck - I decided to swap to SVC's new Baja Bolt On since I eventually will be doing the SVC rear.
They look really similar (obviously) the main differences I can say since having them both:
-SVC skid plates is MUCH heaver/thicker and better looking
-SVC has 4 visible bolts - I prefer not seeing them on the ADD configuration
-Both similarly heavy
-SVC construction is slightly different - I was told one bent piece vs. multiple welded on ADD
-They both look incredible - you can't really go wrong with either
ADD:
SVC:
Hope this helps!
D3 SS 3D
Thanks for that, personally prefer the lines a little better on the ADD here, both look great though.
tom wansor
new york
Could you post pic of side view and tow hook area if you have pics from ADD? Im still undecided between these two but leaning toward ADD.
Droid
kglesq's Brother
Love your truck! Do you happen to know the weight of that bumper? Stock is 50lb IIRC.
Pure745
Pure745
Orange County
I'll have to check to see if I still have some. On the SVC I had them remove the tow hooks and it looks way better.
Thanks! I don't off hand - I can ask SVC. I still have the ADD here - I can try to weigh it.
Rednose
Dubai
Man thanks for the pictures I was planning on changing my ADD to SVC but with the pictures you posted were very similar and i couldn't tell the difference till I saw your shocks
My ADD will stay on the truck. And thanks for saving me some cash.
Pure745
Pure745
Orange County
If I had to pick one - I would go SVC. If I already had the ADD and didn't need to do anything, I would probably keep the ADD unless you're going with other SVC parts.
Rednose
Dubai
Very true if I had the choice again I would definitely go with SVC but my ADD will stay on for now, since I just changed the skid plate on it.
Nice looking truck though!!!
