2020 raptor modes not working ?
raptornice
Los Angeles
i installed an ADD PRO V2 frame cut bumper, and shortly after installation i lost all access to modes. (see attached picture) Has anyone else had this issue??
I also read that mud can affect the modes, I do have mud on the undercarriage that i need to pressure wash and see if that may help.
We did scan it.
Let me know if you have ever had this issue and what helped fix it!!
are you using or did you program a mykey ?
FordTechOne
Detroit
Did you pull DTCs with ForScan? A standard OBDII scanner can’t pull anything other than generic PCM DTCs.
FordTechOne
Detroit
ForScan doesnt show any codes
Did you perform a network test and self test on each module? Some DTCs will not appear as CMDTCs, only as On-Demand DTCs.
If all equipped modules pass the network test and there are no on-demand DTCs, try doing a battery disconnect and do a test drive to see if functionality returns.
onthebrake
Fountain Valley, CA
We did scan it.
BTW, that frame cut bumper set up looks SICK ! I just don't have the balls to do it . . .
