2020 popping noise?
BonesRaptor
Oregon
2020 with Geiser and deavers. While driving at low speeds while turning (less than 10 mph) there’s a loud pop that comes from the drivers side. Can’t tell if it’s front or rear. Any ideas? Doesn’t matter if I turn right or left and seems more prominent when the truck is slightly flexed.
blwn
Cincinnati, OH
How long have you had the Geiser and Deavers? I'd assume loose lower shock bolt or leaf spring bolts. Could also be the leaf springs themselves
Reaper308
I had the same issue with mine, it was my Deavers I talked to Scott at Deaver and it was the pack having an issue with the flex they ended up replacing mine because it got so bad. No issues at all with the new ones. They said it’s very rare but sometimes happens.
B
BonesRaptor
Oregon
About a year now. Ill check all the bolts once it stops raining. Thanks for the help.
Retired in TN
East Tennessee
I also get a clunk during low speed turning. Mine sounds like it is coming from the back end. Doesn’t bother me enough (yet) to deal with it.
