2018 Aux Switch Differences?
Whiterp199
Franksville, wi
Has any wired anything to the 2018 Aux switches? I was installing the Baja designs fog kit tonight and the blunt cut wires by the power distribuation box do not match the raptor supplement or Baja designs directions, well four of them don't.. Also none of these are hot. I am using the bundle on the right side of the truck right behind the battery, is this correct?
Anyone have any suggestions? I am thinking something with my truck is not working.
OffroadAlliance.com
Boston, MA
Wrong set.
Those are just pass through wires. There's another set just toward the passengers side that are the correct wires
---------- Post added at 09:44 PM ---------- Previous post was at 09:44 PM ----------
Feel free to call me if you need further clarification. 781-703-8182. Jeff
W
Whiterp199
Franksville, wi
I saw two sets one toward the driver side just below the ecm connectors and another on the passenger side bundle that runs down past the distribuation box. Is there another set further right?
I put an arrow next to the bundle I am using and an arrow with an x on it to show the bundle that I though was the pass through. Am I mixed up?
shelteredraptor
on a rock
like Jeff said, wrong set. Also, easy enough to simply turn a switch on and check for power at the wires. The set toward the middle of the truck is the set you want. The set to the right side are the pass thru-
OffroadAlliance.com
Boston, MA
Tough to see but it looks like you're in the right spot. Like I said call me it's easier
W
Whiterp199
Franksville, wi
Thanks guys, I will stick a volt meter on both tomorrow, if neither have power I will give you a ring.
I appreciate the help. I am done with it for tonight as my 4 am wakup call is going to roll around quick.
NDO
Other way around, isn't it? The one nearest the passenger fender on mine was hot and the one closer to the center of the truck was pass-through.
WhatExit?
48th state
My suggestion is to search this forum (2017) for "Upfitter" and you would've found what you are looking for
W
Whiterp199
Franksville, wi
I tried searching and read the threads below. i couldn't find anything on possible 2018 differences which is why I asked. I am at the correct location for the hot side on the 2017's but the color of my blunt cut wires do not match the 2017's. Both bundles in my truck have the same color wires which makes made me think this may be a 2018 difference. Really wondering if anyone with a 2018 has noticed the same thing, or used the aux switches yet.
http://www.fordraptorforum.com/f260/wiring-upfitter-switches-53519/
http://www.fordraptorforum.com/f266/aux-switch-wires-pass-through-wires-55376/
http://www.fordraptorforum.com/f260/aux-switch-wiring-51337/
WhatExit?
48th state
Got it, thanks for the explanation.
Does your Supplement show this same info that's in the 2017 version?
91381d1502479007-upfitter-switch-wire-harness-bundle-screen-shot-2017-08-11-12.14.58-pm.png
If not, what does it show?
93,463
56,751
ShockerFL
