GEN 1 2012 stock Sony Amp - does it need to be programmed if replaced?
Dane
Littleton, CO
Title says it all. Apparently my amp cooked. My audio system is bone stock, and I'm fine with keeping it that way. If I find a used amp, do I need to do any programming or will it just work? I'm guessing the amp lives under the rear passenger seat in that black plastic box with that sub? Any one have an old one they wanna hook me up with? I do have the upgraded Sony system - I forget what it's officially called on the built sheet. Thank you!
Jhollowell
Everett, wa
The amp is under your center console. Just curious, if the amp is blown, do other things not work as well? I'm just curious if the amp controls anything besides the stereo.
Dane
Dane
Littleton, CO
Well, there were a bunch of other things that got fried - the amp being one of those. However in terms of stereo, everything works, there is just no sound. No music, no beeps, nothing, but everything else works - Nav, Sync, etc.
Jhollowell
Everett, wa
Well thats good. You might want to look at an aftermarket amp to get your stereo back up and running. might be cheaper than trying to find an OEM amp and you'd likely get better sound quality. PAC Audio makes some harnesses to integrate your stock head unit to an aftermarket amp. @The Car Stereo Company could probably help you out
Dane
Dane
Littleton, CO
Well thats good. You might want to look at an aftermarket amp to get your stereo back up and running. might be cheaper than trying to find an OEM amp and you'd likely get better sound quality. PAC Audio makes some harnesses to integrate your stock head unit to an aftermarket amp. @thecarstereocompany could probably help you out
I priced out an aftermarket one earlier today and it was pretty expensive. Honestly, I'm fine getting back to status quo - I found a used amp for $110 shipped. Thinking that's the direction I will go. The rest of the electrical disaster is bleeding me dry, I just want the sound to work again and to focus on other things. What I don't know if whether or not I need to have the stupid thing programmed - which will cost more than the amp itself.
Dane
Dane
Littleton, CO
Gotcha. i would have thought the OEM amps would be more. Probably the way to go then
New they're like $750 - at least through the shop where we're fixing other stupid stuff. Since we're fixing other stupid stuff, they can throw the amp in for me basically for free (unless programming is required), and they are fine throwing in a used amp. Specifically we're replacing the airbag control module, next to the amp. Long story, electrical heart attack, lots of melted wires with very little explanation, last items are the amp and the airbag control module. It has been an ongoing nightmare since May. I've barely seen my truck since then.
Per the Ford Workshop Manual the Audio DSP Module (amp) requires Programmable Module Installation when replaced.
Dane
Dane
Littleton, CO
Do you know what that entails? Is it Forscan? Some other magical programming? Is it just going to do nothing before that is done (after it's installed)? Thank you for the information.
aka grumpy car stereo guy
yeah, we have been texting back and forth about it. a simple oem replacelemt is all he needs for now. looks like @FordTechOne answered the question of programming. i dont think i have ever replaced an oem amp with another oem amp. looking into it, it seems its a dealer programming requirement. unless the shop has the ford specific scantool
93,363
56,644
LDMiles
