10R80 stuck in tow mode
F100Raptor
Phoenix
Curious of any others have had issue with a 10R80 stuck in tow mode? If so what was the fix?
Not the tow haul button or circuit.
I’ve not seen this myself, nor can I remember reading of it here. Dare I suggest FORSCAN, check for DTC’s?
CoronaRaptor
CANADA
Only thing I’ve seen is a Raptor being towed by a motor home and his raptor caught on fire when in tow mode, can’t remember the specifics on that , but there was some issue with the transmission. I’m guessing you’re talking about that type of “tow mode”
F
F100Raptor
Phoenix
Yes, No indication on dash cluster but obvious stuck in Tow Mode. It should go to normal mode each time key is cycled. I typed it into google and seems a common issue with F150 in general.
F
F100Raptor
Phoenix
Try disconnecting the battery.
I actually ran full scan, I reflashed the transmission, instrument cluster, pcm and bcm to as built. I tested circuit and checked PIDS to make sure the Tow button is working. M mode and - + buttons work fine.
Transmission works great otherwise.
I think its hurting my MPG by quite a bit also. Had hoped for better than 22-25
