Stock Rear Bumper flush LED Lights ?
BeansGT
BeansGT
Florida
Nice great feed back , First mod is lighting and I want to have them to turn on when backing up or driving ( incase of a high beam driver ) . Ill also probably check out those reverse lights as well. I think I will be doing the quads up front and maybe a bar in the center bumper later. Thanks for the input guys much appreciated.
Nick@Apollo-Optics
BeansGT, it's definitely doable to have your lights wired up that way. What you'll do is install the KC flush mounts with the included wiring harness and then connect the it to your factory wiring. Then, you'll tap a second wire into the reverse light wiring on the to tow hitch wiring, add an in-line diode to prevent the power from going back into the trailer wiring, and then connect this wire to the 86 (ignition) terminal on the relay. Now, your lights will turn on when the truck is shifted into reverse and when the auxiliary switch is connected.
Hope that makes sense!
punchinpaper
I use these for the random high beam tailgaiter, its effective at 4:30am for sure.
BeansGT
BeansGT
Florida
Yes got it , Maybe a option . Thanks
I like . Only not sure I want to cut on my tailgate .
