Stock Rear Bumper flush LED Lights ?
BeansGT
Florida
Has anyone did a stock bumber and cut openings to flush mount some LED's in it say Mid sides and on each side of bumper for better reverse or extra lighting on rear of their raptor ? Also wondering if they used them or liked the set up .I'm not going to change my bumpers so using what I have and this will be the only mod to the bumpers .
I found this pic :
https://www.google.com/url?sa=i&rct...9ji0kkJhc1U7zYKmIo2zXhnQ&ust=1455667005222326
HAYNES OFFROAD
aka Wreckless
Bourbonnais, IL
Yea we cut in flush mounts all the time! Rigid, Baja Designs, etc... Have flush mount cubes that work great for bumpers.
Or if you don't want to cut your bumper and have a 100% plug and play reverse light, our hitch light is a great solution!
https://www.haynesoffroad.com/collections/lighting/products/haynes-offroad-hitch-light
2014RubyRed
Galesburg, IL
Just a thought, and definitely not taking away from the above suggestions. They all work and look great! Crown Offroad sells Diode Dynamics reverse lights, and these are probably the easiest thing you can install to improve your back-up lighting needs. Obviously they come on when you are in reverse, but the highest light emitting bulb we offer is amazing. Check out this thread, and used with the other lights you may get, you will be able to see great when backing!!!
http://www.fordraptorforum.com/f248...g-accessories-44780/?highlight=diode+dynamics
Nick@Apollo-Optics
They have those in amber? Do they use the same mount holes as the Rigid Dually's?
Rick, I spoke with KC and they said they could get them made for you if you were interested. I'll have to get the specs to confirm if they will fit in the same spot as a Rigid. I'm sure they're not too far off in size.
