Grounding lights
cdcalaway
When you guys ground out your lights do you do it to the body/frame nearby or run a negative back to the battery?
Sent from my SAMSUNG-SM-G900A using Tapatalk
Deleted member 12951
Depends. I don't have any thing I've added that goes directly to the battery. Everything connected to the battery is factory.
I have a bus bar for negative that connects to the factory ground in the sidewall. For everything in the front, I run negative to that. For things in the rear, I've been running it to the frame.
aka grumpy car stereo guy
i am hesitant to scrape paint to make a good ground in the rear of the truck. i usually run it forward and ground up front somewhere. lights dont draw a lot of current so the long ground is fine
C
cdcalaway
I was just curious as to what most on here do. I hate running any extra wires, so at work I ground to the nearest bolt.
run 14ga speaker wire. it holds plenty of current for lights and since its a pair, you just do one run to the front. i always run extra wires whenever i work on a truck and they want something doen in the back. that way next time all im doing is running wires from the drivers kick panel.
C
cdcalaway
I'm going to run a 0 guage to my cross box, and put all my relays and fuses in there, then run everything from there. I figure I will pull 70-80 amps
---------- Post added at 09:22 PM ---------- Previous post was at 09:21 PM ----------
I am running each pair of lights on there own color
---------- Post added at 09:25 PM ---------- Previous post was at 09:22 PM ----------
One more question. How do I make the power switched?
---------- Post added at 09:26 PM ---------- Previous post was at 09:25 PM ----------
Do I use a coil and run signal from the ignition
