Need mounts/brackets for 40" Lightbar behind grille
bakkbakk
bakkbakk
House
I just jammed a 41" lightbar into a 40" hole. And i ripped out my radiator air deflectors in the process. Lets see yukons instead
ZBoater
I'm thinking 1" spacers and longer bolts while keeping the rubber bumpers might do the trick.
Yukon Joe
Trafford, PA
I did my install so long ago and posted pics already. you'd have to really search to find it. Lol....
I used the supplied M&R bracket. Nothing fancy but an inexpensive headwear L bracket with a slot on one side and a hole on the other.
I upgraded the bolt and nut they mount to the truck with a 1/4" or 3/8" stainless carriage bolt, lock washer and nut. The hole in the frame has a plastic nut on the bottom side. This gives out about your second raptor run. At least mine did. Lol... I pushed the plastic nut out and inserted the carriage bolt from the bottom into the square hole. It really worked out well.
Yukon Joe
www.RUNRAPTORRUN.com
cheapmike13
San Antonio, TX
I just grinded one side down as well as a some of the plastic! I hope it holds
RandM
Surprise, AZ
@cheapmike13 did you replace the plastic nut underneath as mentioned earlier? I have these same brackets and was looking at the grind/trim option. Do you have a pic of how far you went in on the bracket and any interference issues with the radiator/ cooler bracket?
cheapmike13
San Antonio, TX
@RandM I did replace the plastic with a 10mm nut. I don't have a picture but I just trimmed enough off the light bar bracket so I could see the hole and then just widened it with my drill so the bolt will slide through both holes. You are gonna have a small plastic radiator clearance issue but I just cut that piece of plastic off ill try and get pics for you
93,278
56,567
erikn
