Another IWE thread
NorCal Offroad
NorCal Offroad
Sacramento, CA
Turns out the system is fine. You have to go thru the diff warming drive cycle; don’t turn the truck off, jack up the front and check. Both of mine were fine. Trying to pay closer attention to if I only hear it in the first mile when it’s still cold, or if it’s all the time and there’s something else wrong. Still doesn’t explain pulling in 4wd on dirt.
@FordTechOne or @Old-Raptor-guy for the _actual_ explanation, but... IIRC there is a warm up cycle in which the hubs are locked for either a mile or (another condition, which I’ve forgotten ) - I think temperature, and then they will unlock to allow the IWEs to fall to 2wd. Honestly, I rarely used 2wd because I can be... a bit heavy on the throttle.
pat247
Oklahoma
That is because the Gen 2 cannot lock the rear differential in 2wd and the reason the Gen 1 does not have as many problems with the IWEs.
