Tailgate Release Button Not Working
Sonicsunspot
KC
2018 Gen 2 - tailgate release button stopped working. Fob control still works. I replaced the actuator (because it was easy, not necessarily logical). Still no joy.
Trucks been at the dealership 2 days, apparently they think executing the unintended tailgate release recall TSB will fix it. But the guy that does that job is swamped and it will be many more days. Apparently he also specializes in A/C compressors - I can understand why he’s swamped.
Anyway, has anyone else experienced this problem and is the recall fix worth waiting for or is this merely the troubleshooting tree next step???
isis
PA
I had the recall fix done and my tailgate wouldn't open at all. Had to take it back so they could take it apart and do (something?) to fix it. All good now..
Sonicsunspot
Sonicsunspot
KC
Yeah the recall is for unintended tailgate release. I don’t see how that impacts my issues where the tailgate button does not work.
are you sure it doesn’t work? After the TSB, you need to press the tailgate button 2x to open. Truck engine must be off.
isis
PA
I had the recall and don’t have to hit it twice. Only the key fob needs a double tap but it always has.
isis
PA
They definitely changed the harness. But yeah, I don’t think it does that. I’ll check the engine off part.
Old-Raptor-guy
USA
Q
They did not reprogram the BCM then. Which honestly I was thinking of doing without the harness. The harness modification is quite extensive and as a mechanic I have a hard time having others touch my shit.
And to do the recall requires the dealer to do it (I can reprogram BCM myself).
Sonicsunspot
Sonicsunspot
KC
The double tap at the tailgate button doesn’t work for me. Double tap fob works fine. I am pretty sure I have never had the recall done (as hard as it is to get my dealer to do it, must be a pain).
I suppose the button, or the connection at the button could be bad.
BIZZnice
Raleigh, NC
I just posted a similar thread…I have 22’, my tailgate will not delatch, I get a ding when I hit the button. I have tried manual mode in sync and that does nothing, still receive the ding. I have unplugged the tailgate release and Module fuses. The beeping goes away but the tailgate will not move. It’s just a button I have no way to physically or manually open the tailgate. It has been stuck now consistently for over a couple weeks. I do know that it was opened with the truck off and it was manually shut because the button would not close it
