These have been packaged up and will be shipping out tomorrow.
Thanks Rick for setting this up. I finally got a chance to do the install. Couple thoughts:
1. The supplied boots were too big to fit around the steering rack. I used the stock boots and trimmed them per the online instructions from Rogue.
2. The shackle that bolts to the steering rack should be oriented so that the bolt that passes through the heim joint is parallel to the ground.
3. I used the total measurement of the stock tie rod to do an initial setup of the length of the new one. However an alignment is required after install.
Overall very happy with the finished product and it seems to have solved my front end clunk on hard right turns.
