GEN 2 low profile boxlink mounts available?
Toadster
Folsom, CA
the Retrax MX Pro is awesome but the OEM boxlink mounts can't be added/removed once the Retrax is mounted...
any options here?
Turbolag
I have a powertrax mx pro. I installed the boxlinks after the cover was installed. The two closest to the cab are a tight fit, but they work. You can only really access the one the the hook holes on the box links closest to the can with everything installed. Everything seemed to work fine moving two large dressers from Costco. Hope this helps you.
California
I did exactly the same. It is a tight fit, but the two front box links are installable and removable after installing the Powertrax.
