jblakesmith
I currently have Black Widow Race Venom in turn down, no resonator configuration. Cold starts are loud, which I'm fine with since idle sounds great. Interstate speeds above 70 mph is fine as well, but gets loudest (drone) around 1800-1900 rpms, which is cruising in the 65 mph range when traveling roads with 55 mph speed limit. Also got to find some sources of minor vibration in the cab during that rpm range when going through the gears. Anyone else experience this with the setup I have? If so, solutions? Considering trying a different muffler or cat-back with turn down. I really like the clean look of no side or rear tailpipes. I've read that MBRP turndown has more drone? There is also Borla, Magnapack, Flowmaster muffler options as well. Corsa seems popular, but doesn't sell just the muffler or a turndown config. Any others I may have missed? Ones that you recommend or not recommend? Just seeing what others have done and if I want to try something different. Also got to watch more of Youtube. Thanks for your time and recommendations!
