- Joined
- Apr 12, 2012
- Posts
- 1,749
- Reaction score
- 1,218
Thanks for the response. Your response is somewhat confusing in that I have a pair of work/scene lights on order for this exact install. I ordered based upon your website where it says the wide cornering is for lighting zones 1&2 while the work/scene is for zone 7. Can I swap lenses or is it a whole different light?
Did you order our Ford Raptor, Backup Kit ?
https://www.bajadesigns.com/products/Ford-Raptor-2017-S2-Reverse-Light-Kit.asp
If so, the kit will come with QTY: 2 - S2 Sport in Wide Cornering. If you purchased the Work/Scene lights separately with intentions of installing yourself it can be done. The Wide Cornering will just provide a little bit more usable light in that location since these are mounted so low. If you want to change from the Work/Scene to a Wide Cornering pattern it would involve QTY: 2 - S2 Wide Cornering Lens kit and QTY: 4 S2 Spot Reflectors. It's not a direct lens swap since the reflectors are what controls the pattern on the Work/Scene light.
