GEN 2 Installed CJ Pony 1.5” Coil Spring Collars
10SpdsOfFury
Jacksonville FL
Was pretty straight forward and they have a great video on how to, the Quality is good and over all a nice product.
The ride is a tad stiffer but much less nose dive under braking and better cornering, I did manange to hit my favorite dips on the way home and the truck seem to take them a lot better. I plan on getting it aligned next week to double check everything.
xxaarraa
Southlake, TX
Looks great, nice job!
I spoke to RPG engineers about this in detail, and they explained that any perceived ride quality difference after a 1.5" collar is entirely in your own head. The spring rate does not change by adjusting preload (which is what you are doing by installing a collar) and 1.5" is not enough to change LCA angle either. So... your truck still rides the same as stock, but is a tad taller in front.
10SpdsOfFury
10SpdsOfFury
Jacksonville FL
That is a interesting point. Maybe by raising the front up and changing the pivot angle front to back is what I am feeling when braking and acceleration because it’s a lot less noise dive and lift. Also when turning with or left really quick it doesn’t lean like when stock, it feels more like my Paltinum.
I could just be crazy and we can’t rule that out all together. Lol
RWE
Burbank, Ca
Shouldn't change at all if the springs are linear which I thought they were. the same amount of force (Braking or bump) would cause the same amount of dive regardless off spring compression until it bottomed out. If they are in fact progressive, then all of this goes out the window.
Mink
Oregon
Looks great, mine are suppose to be here tomorrow.
RWE
Burbank, Ca
Has anyone jumped their truck with these on? I got a set and haven't put them on yet but they felt kinda cheap. Blows my mind that they can support all the forces of this truck landing from 4 feet in the air.
10SpdsOfFury
10SpdsOfFury
Jacksonville FL
I just looked it up and the CJ Pony parts are made of 6061T6 Aluminum and RPG just says made from same material as fox shocks. Fox says they are made from 6061T6 Aluminum so I think we are ok. Plus they are made in America so we should be good. #Murica
RWE
Burbank, Ca
6061 isn't nearly even the strongest aluminum. and it seems pretty thin in some places. Guess I'll play test dummy soon.
10SpdsOfFury
10SpdsOfFury
Jacksonville FL
I just meant Fox Shocks and RPG Collars are all 6061, I hit the two big dips that I always hit at 60 and it was solid as a rock.
93,180
56,460
khunter
