GEN 1 Putco 40" Curved Luminix LED Light Bar
oplersx
British Columbia
The bar has 6 degrees radius... does it match GEN 1's grille?
If the curve matches well, seems like a good spot to mount.
O
oplersx
British Columbia
4x4TruckLEDs.com
I can't confirm nor deny it will fit. It should fit on the outside of course.. but you have to drill holes in. This is not a bolt on installation. if you want a bolt on installation you can checkout the Baja Designs Grille kit which is a 40" Bar that bolts on behind the grlle:
Baja Designs Ford Raptor (2010-2014) OnX6 40" LED Light Bar Kit - 4x4TruckLEDs.com
Those that have installed hte Putco bar had to drill holes in since it's a universal bar
O
oplersx
British Columbia
A bit of update, brought a 40inch curved, it FITS inside the grille! Just have to figure out the best way to attach it to the grille. Won't be difficult I think, have an idea, shopping for couple small hardwares tomorrow.
O
oplersx
British Columbia
Mounted, perfect solution for guys like me who has an extra radiator (supercharger) in front, except the bar's price tag.
smoothie
That looks fantastic, had to look a few times to see where it was! How is the output and what was the $?
