cv axels
ogdobber
my boots are starting to leak (2012) both sides
whats everyone doing for replacements? are there better aftermarket or just new oems?
and new part number is this the one? MOTORCRAFT TX779
ogdobber
ogdobber
Different one for each side
Left AL3Z3A427C
Right AL3Z3A428C
RCV is the better aftermarket product but you pay for it
Ultimate IFS CV Axle Set for Ford F-150 Raptor ('10 -'14)
WOW $2700!?
i don't drive mine hard enough to justify those i dont think
on rock auto one cross refences and the other doesnt...
MOTORCRAFT TX779 {#TX537, TX580} $168
MOTORCRAFT TX780 {#AL3Z3A428C, TX536, TX579} $183
http://www.rockauto.com/en/catalog/ford,2012,f-150,6.2l+v8,1503276,drivetrain,cv+half+shaft+assembly,2288
---------- Post added at 01:48 PM ---------- Previous post was at 01:32 PM ----------
adding this for reference. need to order by end of summer
rock auto code
5% Discount Code: 8A8FD672225447
Expires: September 20, 2017
Otis857
Glendale, az
Are you going to replace the whole axle shaft? If your CV's are still good, its not that bad of a job to replace the boots alone.
ogdobber
ogdobber
Hmm i never thought about that...
However i do have a concern, this winter i was getting a "popping" where the locking ring was either slipping on worn gears or it was just way cold and maybe the grease thickened up and it wasn't going into full seat. Now that i think about it, down in Mexico it was really hot with some very steep technical climbs and it never popped
Otis857
Glendale, az
Are you sure it came form the CV's? That sounds like the infamous IWE problem. I've gone through 2 already and i dont 4 wheel too hard. Ford's "better idea" cheaply implemented. Thats a quick change out while you have the axles out.
ogdobber
ogdobber
Well ill probably change the iwe as well. Start fresh.
SVTLOPEZ
popping is the sound I have.
