Amsoil 500 DOT 3 vs 600 DOT 4
bossman216
Everywhere
The truck mainly stays on the hwy. Some off roading but never at high speeds. Which is better and why?? Thank you for any info.
Chris@FreedomMotorsports
FRF Gofur
Woodlawn, Virginia
The DOT 4 is better because it has a higher wet boiling point. While both are good, brake fluid absorbs moisture like no other fluid out there. The wet boiling point determines how hot the fluid can be before it breaks down and stops doing it's job.
Brake fluid is subjected to very high temperatures, especially in the wheel cylinders and disk brake calipers. It must have a high boiling point to avoid vaporizing in the lines. This vaporization is a problem because vapor is highly compressible relative to liquid, and therefore negates the hydraulic transfer of braking force, so the brakes will fail to stop the vehicle.
https://www.amsoil.com/shop/by-prod...ries-600-dot-4-racing-brake-fluid/?zo=1678239
downforce137
In Diana
I always ran Motul RBF600 in my race bikes, and will change the raptors fluid pretty soon. Its always done really well in the tests, and is reasonably priced.
B
bossman216
Everywhere
Thanks Chris! I appreciate you taking the time to type all that out. Very good info.
Jimbo
Mad Frog Mattis
IL
I know, but I liked the blue!! Makes it easier to tell you have the old fluid out when you are flushing it. Plus I think the DOT ruling was dumb.
Meh, I was never a fan of blue, stains the reservoirs. Plus, it's not hard to tell with the TYP 200, the old fluid gets pretty dark - usually use 2-3 liters when doing a true brake flush.
EricM
OHIO
I liked the ATE SuperBlue, but DOT recently outlawed it because it is not clear or amber...
I never liked the blue because it stains the plastic in the MC and you can't tell when it's getting dark like amber.
93,202
56,485
bjorn-dpc
