Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 1]
Gen 2 OE rear shocks on gen 1
This is a discussion on Gen 2 OE rear shocks on gen 1 within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Originally Posted by ogdobber Im sure the gen1 springs will work, however thats not the problem. Even with a 1.5 ...
Like Tree75Likes
Sponsored By: Fox - Redefining Ride Dynamics
Old 12-03-2017, 05:40 AM   #71 (permalink)
Originally Posted by ogdobber View Post
Im sure the gen1 springs will work, however thats not the problem. Even with a 1.5 inch spacer block, the upper a arms crash into the spring at full drop (not to mention the severe angles on the cv's.)
That pic of the side by side isn't mine...but it looks closer to 3 inches which would make the above problems even worse.
What @downforce137 said, the best solution is to move the buckets up
Yes i agree moving the upper bucket would be a fix. I agree the Gen2 is longer overall as is, and i would NOT install the 1.5 lift block. With the truck on the jack stands and suspension hanging free, the guy that installed the front didnt mention anything about the shock or coil running into the upper control arm. Only issue reported was that the spring rubbed on the driveshaft at ride height, and the spring was close to the frame at ride height. the coil on the Gen2 is much bigger in OD, which is causing the issue.
Still waiting on a few more measurements.
Jimster58 likes this.
bamared is offline   Reply With Quote
Old 12-03-2017, 11:40 PM   #72 (permalink)
Junior Member
Gashawg likes this.
Chevydillan is offline   Reply With Quote
Old 12-04-2017, 03:54 PM   #73 (permalink)
Gashawg's Avatar
Junior Member
Based on all the comments, it would seem the Gen 2 front and rear would work well on a lifted Raptor if the Gen 1 coils will fit the Gen 2 shock
Gashawg is offline   Reply With Quote
Old 12-04-2017, 09:10 PM   #74 (permalink)
Junior Member
just bought a set of gen 2 takeoffs with 20 miles for 999 shipped.... I will get a bunch of accurate measurements when they come in. I am convinced this setup can be made to work.
Jimster58 and bamared like this.
jpwrx2002 is offline   Reply With Quote
Old 12-05-2017, 01:38 PM   #75 (permalink)
So there are no issues with the rear shocks fitting and functioning properly? Iím very interested in starting this but want to make sure.
Gashawg likes this.
07Alloy is offline   Reply With Quote
Old 12-05-2017, 04:19 PM   #76 (permalink)
Aaron's Avatar
Lengths are different. That could affect lots of things under full droop/compression.
AndysLog and Smokeshow60 like this.
#WHATAREJENNIFERS
Aaron is offline   Reply With Quote
Old 12-05-2017, 04:46 PM   #77 (permalink)
Very possible and also likely. And I'll add, if at normal ride height the piston is in a different location inside the shock body this will also affect compression and rebound damping during normal road driving as well possible making road manners harsh or even possibly intolerable.
Smokeshow60 is offline   Reply With Quote
Old 12-05-2017, 06:50 PM   #78 (permalink)
Aaron's Avatar
It's all about how much thrust per squeeze the Gen2 shocks are capable of....
#WHATAREJENNIFERS
Old 12-06-2017, 10:35 AM   #79 (permalink)
I would think the real question would be how long are they when mounted. Are they mounted still in the same range as they are on the gen 2. I have deaver 3+ on the rear. That adds some height and could potentially put the gen 2 shocks closer to stock range but Iím sure mounting points could be totally different distances between generations.
I would like to hear from anyone who has already had them mounted as to the feel of them at least.
Also. As a side note. Someone some time ago mentioned getting a hold of Walter at Aftermarket Headquarters I think itís called. They said he knew how to make these work. Not sure, but thought I would throw it out there.
Old 12-07-2017, 12:12 PM   #80 (permalink)
if you read the thread, the information is there. They mount exactly the same. the bigest difference is the Gen2 mount 1 forward and 1 facing the rear. So the stick is on the inside when mounted on Gen1. lol
So, worried about having the same stroke.. and travel position on the piston? should not be an issue, they can be adjusted by nitrogen for a precharge correct? so you can adjust them a little i would guess. also, deavers +3 would be perfect anyways. removes 2" block and adds an inch.. sounds like a win win to me
Jimster58 and Gashawg like this.
FS - Stock Suspension: Front Shocks, Rear Shocks, Leafs jakehobbs Garage Sale 11 03-07-2016 12:36 PM
Icon RXT Rear Shocks and Rear Springs In Stock SDHQJASON Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 70 09-10-2015 11:36 AM
Icon RXT Rear Shocks and Rear Springs In Stock SDHQJASON SDHQ Offroad Racing 1 03-07-2015 02:04 PM
WTB Rear Shocks jnall Want to Buy 3 09-21-2014 05:31 PM
WTB - Fox Rear Shocks cjhmcox Want to Buy 0 08-21-2013 08:23 AM
