Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 1]
Ball Joint replacements
This is a discussion on Ball Joint replacements within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Has anybody had to replace lower ball joints on their LCA's. What is a good replacement. Moog? stock Ford? or ...
Like Tree9Likes
Sponsored By: Fox - Redefining Ride Dynamics
Old 11-03-2014, 08:40 PM   #1 (permalink)
Mil T's Avatar
Default Ball Joint replacements
Has anybody had to replace lower ball joints on their LCA's. What is a good replacement. Moog? stock Ford? or are there any heavy duty ones available?
tbone and TornadoRaptor like this.
Iron Horse Cowboy
Mil T is offline   Reply With Quote
Old 11-03-2014, 09:04 PM   #2 (permalink)
All The Way's Avatar
I went with Moog, lifetime warranty
MOOG MOOG-K500193 Suspension Ball Joint Made by MOOG
All The Way is offline   Reply With Quote
Old 11-04-2014, 09:37 AM   #3 (permalink)
SDHQJASON's Avatar
Replacing ball joints is not uncommon as they are a wearable component. Replacing them is regular maintenance just like changing your oil. (Obviously much greater intervals)
We always use the OEM Ford joints as they are the strongest and typically the longest lasting. Check your control arm bushings while you are at it. They also go bad. If these are worn out as well, I would recommend replacing the whole lower control arm.
SDHQJASON is offline   Reply With Quote
Old 11-04-2014, 02:42 PM   #4 (permalink)
KaiserM715's Avatar
Kaiser Söze
Looks like these have grease zerks - as all ball joints should. I will use these when the time comes.
---------- Post added at 01:42 PM ---------- Previous post was at 01:40 PM ----------
FYI - @RockAuto has them for $47.79 ea.
More Information for MOOG K500193
'10 Raptor - My build
'08 G8 GT
- sold
'04 MazdaSpeed Miata
'67 Jeep Kaiser M715 - sold
Join the Blue Ribbon Coalition . . . it's YOUR Public Land!
KaiserM715 is offline   Reply With Quote
Old 11-04-2014, 05:38 PM   #5 (permalink)
Jordan@Apollo-Optics's Avatar
aka LSUstang05
That's what I have. Moog serviceable ball joints with a grease zerk. I give them a shot of grease every oil change.
KaiserM715 likes this.
Authorized Distributor for
Facebook | Instagram
Contact Us: [email protected]
Site: www.apollo-optics.com
Jordan@Apollo-Optics is offline   Reply With Quote
Old 11-04-2014, 05:42 PM   #6 (permalink)
Yukon Joe's Avatar
Do any of you guys have install pics?
@All The Way when did you change yours out? How many miles?
Buy a raffle ticket for Avery: win an awesome prize.
November Pay It Forward Event!
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline   Reply With Quote
Old 11-04-2014, 06:04 PM   #7 (permalink)
I changed them out a little before time attack. Sorry Joe, no install pics.
Old 11-04-2014, 09:15 PM   #8 (permalink)
Mil T's Avatar
That's a great price. I did find them at O'Reilly's for $89 which I thought was a little steep. Napa wanted $99. I was afraid to check the Ford dealer on an OEM one. I only bought one for now but may go ahead and order from Rockauto and pick up another one. I have a clunck on the driver side that I can't figure out. I'm thinking it may be the control arm bushings. The ball joint is pretty tight. I've checked all the bolts and nuts on shock. I'll put it on lift and check it out. Any suggestions on how to determine if bushings are bad? I'm not sure if lifting tire method like you do to check ball joint is a good way or not. Is there a easy way to check bushings?
Iron Horse Cowboy
Old 11-04-2014, 09:30 PM   #9 (permalink)
That's a tough one. I tried comparing my bushings to a new truck and I could tell the difference. They both had the same amount of play.
Old 11-05-2014, 11:20 AM   #10 (permalink)
KaiserM715's Avatar
Kaiser Söze
Be sure to check their section on our forum (they are supporting vendors) to get a 5% discount code.
Sigma Pi likes this.
'08 G8 GT
- sold
2011 Headlight Bulb Replacements? Mark Ducati Ford Raptor Lighting Modifications Forum [GEN 1] 37 02-13-2018 11:34 PM
Ball joint out at 38k miles Stang Ford Raptor Problems and Questions Forum 3 07-28-2014 11:04 PM
iPhone and iPad Screen and Battery Replacements! BearLeeAsian Garage Sale 1 07-01-2014 08:36 PM
Icon stock replacements?? Off Road WannaBe ICON Vehicle Dynamics 25 04-01-2013 03:04 PM
OEM Tire Replacements: $200 each? BigJ Ford Raptor Wheels & Tires Forum [GEN 1] 1 06-26-2010 06:39 PM
