mprice1234
SVT Gen 1 Rules
Ok there in and I'm whooped! The drivers side was impossible to mount, there is a hard plastic piece right above and hangs down in front of the outer bolt so the bolt won't come out without a great deal of force to push it up out of the way. That's not very easy trying to hold the light assemble and start the bolt. I think the brackets need to be redesigned so the light mounting bolt/nuts can be reached. After installing the lights if you need to adjust the side to side the lights can loosen up and you can't get to the nuts behind the bracket. My drivers side outside light bracket (chrome piece for up and down adjustment) hits the top of the bumper cut out so I can't turn it in enough. I have them set up exactly as the pictures on M&R's web page. I did wire to one switch for all six. I'll get some pictures tonight to show the lights output. The lights look really nice and the quality seems to be good.
