Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Maintenance Forum
Unknown noise?
This is a discussion on Unknown noise? within the Ford Raptor Maintenance Forum forums, part of the Ford Raptor Forums - General Information category!
I hope this is the right place to post this question. So I just picked up my new to me ...
Like Tree1Likes
  • 1 Post By Raptorchief
Old 03-09-2017, 05:40 PM   #1 (permalink)
Raptorchief's Avatar
Junior Member
Default Unknown noise?
I hope this is the right place to post this question. So I just picked up my new to me 2011 Raptor. The truck has 27k miles on the ticker. So here is my dilemma. I have been hear what sounds to be like a rattling noise coming from the front left wheel area of the truck. It kind of sounds like heat shield rattle mixed grinding noise. It is pretty loud when it happens. It only makes the noise when performing light to moderate acceleration. It does not do it a parking lot speeds, only when driving around town. It will stop if I lift on the accelerator pedal or when I get to higher RPM (above 3500 RPM) under heavy acceleration. Once I am at highway speeds and lightly using throttle to maintain speeds, it goes away. Now here's the kicker. When I place the truck in 4wd, the noise is not there. I don't feel anything in the steering, gas pedal, transmission, or floor board. It is just a sound that is heard. I would appreciate any help that can be provided as to what this noise is. Thank you
Raptorchief is offline   Reply With Quote
Old 03-09-2017, 10:20 PM   #2 (permalink)
Prybar's Avatar
Check all the sheet metal heat shields around the exhaust. Could be a loose one, or one that has a rock sitting in it and making noise.
Prybar is offline   Reply With Quote
Old 03-09-2017, 10:30 PM   #3 (permalink)
SeXualAVENGER's Avatar
I'd guess iwe or vacuum line to the iwe. Iwe issues are well documented in the forum
2012 Tuxedo Black SCrew
Vision X hood HIDs, Retrofit HID lights, Method double standards/goodyear duratracs, Icon 3.0's, linex, plastidip fenders, 5 star tune, hennessey CAI, Borla exhaust, ADD venom winch bumper, M&R behind grill 40"/30" LED bars, bakflip F1.
SeXualAVENGER is offline   Reply With Quote
Old 03-10-2017, 11:26 AM   #4 (permalink)
Junior Member
I have checked all the heat shields and my next thing will be the IWE. Oh and I found out today that it only does it after I drive the truck for a few minutes.
Old 03-10-2017, 04:35 PM   #5 (permalink)
Crash33's Avatar
IWE may have a small leak... If they are pulling some vacuum, they may be partially engaged. Pull vacuum lines off hubs and see if it goes away. Then get a small handheld vacuum pump and see if lines hold a vacuum.
Alter ego of whoisbigman... (I'm at work today)
Crash33 is offline   Reply With Quote
Old 03-10-2017, 04:54 PM   #6 (permalink)
Dane's Avatar
IWE
2012 Black SuperCrew Roush Raptor
2015 BMW S1000RR
2016 BMW S1000RR (yes, we have two)
2008 Mercedes SLK 280
2003 Jeep Rubicon (sort of)
Dane is offline   Reply With Quote
Old 03-12-2017, 11:35 PM   #7 (permalink)
Junior Member
I want to thank you all for the help. I went and bought a vacuum gauge/pump today. After reading the pressures at the pump and then comparing it to the vacuumed at the actuator I found out that it was a vacuum leak. I rednecked it until I get all the new hoses from the dealership on Tuesday.
P.S
The dealership offered me a job after seeing my redneck injenuity.
SZDZMTR likes this.
Old 03-12-2017, 11:55 PM   #8 (permalink)
CoronaRaptor's Avatar
P.S
That doesn't say much for the dealership when they like McGyver repairs! Lol
CoronaRaptor is offline   Reply With Quote
Old 05-20-2017, 08:26 AM   #9 (permalink)
Dicer07's Avatar
Junior Member
Default right dont know if you solved that but..
ignore
had problem a while back on my right front had it at dealership for 2 weeks they kept saying it was my bumper rattling lmao but they were wrong like most of the time
anyways turned out to my front right cv axle had broke
if the noise is the same as what i had
the easiest way to tell is to pop it into 4x4 and if the noise stops you know its the cvaxle
Last edited by Dicer07; 05-20-2017 at 08:27 AM. Reason: saw that proplem was fix my bad
Dicer07 is offline   Reply With Quote
Tags
front end, rattle
New Member and unknown switch on my lower dash! jetrocker Ford SVT Raptor General Discussions [GEN 1] 38 09-27-2015 01:33 PM
Unknown wire? Bulletnjm Ford Raptor Maintenance Forum 17 04-20-2015 06:42 PM
unknown front end noise vibration 4wd????? BRAAPTR Ford Raptor Problems and Questions Forum 6 02-16-2015 02:21 PM
Unknown Bed cage/Rack Netix Ford Raptor Exterior Modifications Forum [GEN 1] 12 06-06-2012 05:12 PM
