MarkT
- Joined
- Mar 4, 2010
- Posts
- 1,202
- Reaction score
- 26
Thanks Guys...That was my main concern considering I run E85 a ton...I will probably just toss it in there before I have to do my next oil change.
Just so we're clear Jesse... you can run Seafoam in the oil for a short time before draining to clean out sludge in the crankcase. I would not recommend this in a new Raptor.
But a can in the gas tank to possibly clean the injectors, etc? That couldn't hurt but from J's post it doesn't appear necessary. (still makes me wonder why Ford requires you to run a tank of gasoline every once in a while. My guess was gasoline has more detergents.)
I bought an older motorcycle cheap recently... wouldn't idle. Previous owner had estimates for hundreds of $ to remove and rebuild the carbs. I figured I'd tinker with it in my spare time and the price was right. Before I tore into it, I filled the carbs up with straight Seafoam and let it sit overnight. Started it up the next day and ran some more straight Seafoam through it. Smoked like hell for a bit (it's supposed to on straight Seafoam) and now it runs like new! never touched it with a wrench. Seafoam does work.
