Technically, amsoil Sig series is rated for 25k miles (when paired with they're EA oil filter). With that said, it depends on your driving style, driving environment, etc...
Personally, I use amsoil Sig series and the EA filter and change mine every 5000, and/or before and after a offroad excursion (where I'm constantly hard on the throttle and conditions are dirty). I send in my oil to be tested and have always came back great and could easily put another 5k on it. I come from a racing background, so its common practice to change all the fluids after a weekend of racing.
Oil filters are the key to oil life (I have not personally ran the ford racing filter so I cannot comment on its quality) and oil filters have a service life as well. As an example, the amsoil EA oil filter is rated for the same 25k as the oil. If your filter is rated for say 10k miles (example), then you would need to change the filter and oil, or at the very least change the filter and send in an oil sample for testing.
So for you, I would reccomend sending in oil samples every 5k (not draining) to Blackstone labs and get your TBN test. That's truly the only way for YOU to find out YOUR personal drain intervals. Everyone can reccomend a certain drain interval, doesn't mean that will work for you.
-Joseph Haynes
