beemerman
I decided to change out the front and rear differential fluid. Also the transfer case fluid. Thanks to Chris at Freedom motorsports for the fluid I needed and the quick service. Removed front and rear covers and drained the fluid. Was concerned because the fluid did look a little milky. Now truck has 8000 miles. Never been in water. Was at Snoball last year but we never did hit any water cause everything was froze. Front and rear fluid looked the same. After draining fluid, what was left in the very bottom of the diffs in the little pocket looked like this. Now only thing I can figure is this must be some type of additive. I am sure a few of you have changed your diff fluids, anyone else's look like this. Transfer case fluid looked in good shape. Just doing this as maintenance. Prepping for Snoball 14.
Sent from my iPad using Tapatalk HD
