Specs on this Raptor?
BlackReef
Anyone know what suspension mods are done to this truck? Also, are those 37x12.5s?
pirate air
will plunder your booty
"Starting with a 2012 new full crew cab 4 door Ford Raptor truck the team set out to do a full 4130 roll cage, 4 link rear suspension with 23” of travel and a full front suspension conversion. The front arms, spindles, and upper arms were re-fabricated from 4130 plate and lengthened 3” per side to give the truck a full 91” wide track width and 17” of travel with full 4 wheel drive. Check out the full build pictures in the gallery."
pirate air
Yes,
"When the Special Olympics of Arizona wanted to do a special build project to raise money for their charity cause they contacted Greg Foutz and the Foutz Motorsports team team to build their new custom Raptor Pre-Runner. Starting with a 2012 new full crew cab 4 door Ford Raptor truck the team set out to do a full 4130 roll cage, 4 link rear suspension with 23” of travel and a full front suspension conversion. The front arms, spindles, and upper arms were re-fabricated from 4130 plate and lengthened 3” per side to give the truck a full 91” wide track width and 17” of travel with full 4 wheel drive. Check out the full build pictures in the gallery."
