towing four down
Glassman
Santa Clara
Can get some pictures if needed I used the Roadmaster brackets with a Roadmaster BlackHawk 2 10,000lbs. Tow bar I had used to tow my pos suburban the tow bar is where you want to spend a little extra IMO get one that allows it to self lock after you hook it up. This makes it so much easier that a fixed tow bar. My first tow bar is a fixed to use on my smaller toad CR-V and I still have that set up and it can be done with only one person but it can be a challenge.
I would recommend this set up as I have used it for ten years with no issues, as for a self install yes it can be DIY even if you have basic tools, must have a torque wrench
will1668
Question
I want to buy a 2012 with very high mileage...177000. The owner said most of the miles are from the vehicle being towed. I have seen mixed opinion on this and hope someone knows the answer...the question is...
will the miles show on the odometer when a Raptor is towed? Thanks
Will
