MarkT
- Joined
- Mar 4, 2010
- Posts
- 1,202
- Reaction score
- 26
Sounds like the system is dropping one of the sensors...
Yes, it does... but from the research I've done on this issue, replacing the sensors doesn't always work. (as in the case with the OP) So it needs to be something else. There is one common denominator in my case. Every time I've had a sensor failure warning, I've had an FMRS radio in the truck. Could the FMRS be interfering with the RF signal between the tire sensors and the receiver? I believe the radios operate in the 462 to 467 MHz frequency range and the sensors are at 315 or 433 MHz?
(Or? There are many different "claimed" frequencies. But this link indicates the 2009/10 F150 can use *either* 315 or 433 MHz. http://www.f150online.com/forums/20...equency-2009-f-150-tire-pressure-sensors.html )
From what I understand, the sensors can be AM or FM... again, not sure what Ford uses but my guess is FM. There have been reports of aftermarket electronic equipment, even cell phones, alarms, dvd players, and in-dash head units possibly interfering with the TPMS signal?
