Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford SVT Raptor General Discussions [GEN 1]
Steering instability around corners
This is a discussion on Steering instability around corners within the Ford SVT Raptor General Discussions [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Hi, has anyone experienced a gen1 Raptor have a steering shimmy when going around a corner with a bump in ...
Like Tree1Likes
  • 1 Post By drewpotter
Old 07-31-2017, 06:26 AM   #1 (permalink)
Junior Member
Default Steering instability around corners
Hi, has anyone experienced a gen1 Raptor have a steering shimmy when going around a corner with a bump in the road? It progressively has gotten worse where particularly at highway speed around a corner, a small bump or crack in the road makes the steering wheel want to move further in the direction of the turn as you go over the bump. Depending how fast you are going, the truck borderline gets out of control for a fraction of a second and you want to put 2 hands on the wheel. My suspension is pretty much worn out in the front and leaking so I am replacing it hoping this is the reason for the issue. I have no reason to believe there is any damage to anything and I had the front end checked out, with the only diagnosis that my shocks were shot. Any comments/ ideas would be much appreciated. (2011 Raptor, 125,000km)
drewpotter is offline   Reply With Quote
Old 07-31-2017, 06:30 AM   #2 (permalink)
waddellw's Avatar
My front suspension blew at 75k miles and now I'm at 95k with all blown, I can kind of get a feel for what you have going on but I feel like it could also be power steering related. How heavy is your steering? Not revving at all sitting still is it exceptionally hard to turn? I've blown 2 power steering pumps and that's when I've gotten the two hands on the wheel at all times.
Also since it is happening at higher speeds what tires do you have and are they balanced well? I had a set of Mickey Thompson Baja claws and those shook like mad all the time. They got out of balance and stayed there.
(My stats are in miles not km)
waddellw is offline   Reply With Quote
Old 07-31-2017, 06:53 AM   #3 (permalink)
Junior Member
Power steering feels fine... wheel is easy to turn at speed or sitting still. the shake around corners is almost as if the wheel is too easy to turn and you have to put 2 hands on the wheel to not oversteer. I think replacing the front suspension is the likely fix as it kind of feels like there is no dampening and you are just bouncing on springs. Got fairly new stock Raptor tires and there is no shaking whatsoever in a straight line so all should be balanced...
---------- Post added at 06:53 AM ---------- Previous post was at 06:49 AM ----------
When your suspension blew, did it go all at once/ was it obvious? Or over a length of time? how did it handle when it went? Where did you purchase your new shocks and how$?
waddellw likes this.
Old 07-31-2017, 07:03 AM   #4 (permalink)
waddellw's Avatar
I know the feeling of bouncing on springs. It does move around a lot more. Riding springs gives no resonance dampening so they do tend to shake and keep shaking. Get a rebuild or a little upgrade and hopefully that'll solve your issues!
---------- Post added at 07:01 AM ---------- Previous post was at 06:54 AM ----------
To add on, my front passenger side started leaking first, it started to lean a little and the bumps on that tire got much more pronounced. Soon after the driver's side have way also and they slowly but steadily got rougher and the front sat lower and lower. Offroading bumps and potholes got to a painfully rough level even slowing down a bunch. A few thousand miles later the rear started to act off, it was rougher too.
I noticed the lean to a side and I looked at the shock and physically say some fluid coming out where it was easy to tell something was off
Everyone I know has asked if I lowered my truck on the front, it sits a fair amount lower than normal.
On one of the raptor shock exchange sites I found this sheet and I believe it. Before they blew and got really worse I did notice a decline in performance even way before they started messing up.
---------- Post added at 07:03 AM ---------- Previous post was at 07:01 AM ----------
I don't have new shocks yet, still deciding between a big upgrade or a shock exchange. But I'd say after 40k miles the noticable decline began and then hit bottom when they gave out
Old 07-31-2017, 07:06 AM   #5 (permalink)
Junior Member
Yeah I got my name on the list for a rebuild at Ford Raptor Fox Shock Exchange Program – Forged Offroad – We Rebuild Shocks. I think the suspension rebuild will fix the whole issue but just checking to see if there might be more going on. Thanks for the help!
Old 07-31-2017, 07:07 AM   #6 (permalink)
waddellw's Avatar
Yeah I got my name on the list for a rebuild at Ford Raptor Fox Shock Exchange Program Forged Offroad We Rebuild Shocks. I think the suspension rebuild will fix the whole issue but just checking to see if there might be more going on. Thanks for the help!
Sure thing man, let me know how the exchange goes if you go through with it I've been looking at that place!
Old 07-31-2017, 11:30 AM   #7 (permalink)
Aaron's Avatar
Meme Corps Commandant
It's 100% your shocks doing that, Mine did the same thing when they were blown.
COMMANDANT OF THE MEME CORPS
MCLTW!
It is not who we are that matters....what matters is our memes...
Aaron is offline   Reply With Quote
Old 07-31-2017, 02:58 PM   #8 (permalink)
Raven13's Avatar
Yep, blown shocks.
Raven13 is offline   Reply With Quote
Old 07-31-2017, 03:17 PM   #9 (permalink)
whoisbigman's Avatar
Find Walter Burch at Aftermarket HQ. You need new shocks or a rebuild. Also, removing front sway bar keeps tires more planted in corners, but allows truck to lift a lot and roll more. after you get used to it, it's more fun to drive.
2012 Tux Black, Loaded. Previous owner added Spray-in liner, bed cover, LED everything, AFE intake, Magnaflow Exhaust, mid-perch... other stuff I haven't found yet. Thank You whoever you are... I have added 37" Nitto tires, painted speaker grilles, Roush vacuum gauge for hubs.
whoisbigman is offline   Reply With Quote
Old 07-31-2017, 07:30 PM   #10 (permalink)
Lugnut2683's Avatar
I highly suspect that your shock is blown. I had similar symptoms, a leaky front passenger side shock, had it rebuilt, and all symptoms gone.
______________
IG: @lugnut2683
Lugnut2683 is offline   Reply With Quote
Tags
shake, shocks, steering, suspension
Used 3.0s all four corners blclay24 Want to Buy 1 05-21-2016 07:09 PM
Oem stock fox shocks all 4 corners + upper control arms Pt2285 Garage Sale 4 11-02-2014 01:05 AM
OEM shocks all four corners rap67 Garage Sale 23 10-22-2014 07:21 PM
Handling in the corners HiGCorners Prospective Raptor Owners 25 04-04-2013 07:58 PM
TSB 11-12-11 - Lack of steering assist or excessive steering effort pirate air Ford Raptor Recalls | TSB's | SSM's 0 05-16-2012 02:51 PM
