2 bikes, 1 bed
stewwalker
stewwalker
Kingsville/Houston
Ok. I did some research, the total payload capacity is +-1000 lbs. INCLUDING passengers. I'm definitely going to be in the danger zone...
Some one school me on increased payload capacity when using the SVC bump stop kit, please. SVC's website doesn't give increased payload specs.
CoronaRaptor
CANADA
The bumpstops (NO KIT) do not give you more payload capacity. They will on the otherhand protect your frame from bending. You would need to replace the rear springs, if you are worried about it.
Bulletnjm
New Jersey
Ok, you should look into HD springs. A bump stop kit like the svc abs kit will allow you to lower the bumps, allowing less travel, but at the same time helping out the springs by taking some weight off of them. Legally no company is going to tell you these mods will increase your payload capacity. If you where to get in an accident and someone where to start looking around and where to find you where above your legal limit, you could get in some serious trouble
stewwalker
stewwalker
Kingsville/Houston
I figured this much. No actual info from SVC on the "increased payload capacity". Any first hand experience? I don't want to go to HD springs because I don't want to sacrifice off road performance...
Bulletnjm
New Jersey
Well even standard duty springs will allow 100 or so extra lbs in the bed, and will improve the ride quality both on and off road
t_j
Chicago, IL
It should be noted nothing increases your payload but there are options to improve handling close to payload and at payload handling.
stewwalker
stewwalker
Kingsville/Houston
Well screw it. I'll just run it stock for now. If something gets worn out or breaks I'll have an excuse to get deavers and bumpstops.
FYI, I started weighing loaded gearbags and action packers. A gearbag (boots, helmet, knee braces, ect.) is under 40 lbs, and a loaded actionpacker (tools, oil, tubes, spare parts, ect.) is between 35 and 45 lbs.
CoronaRaptor
CANADA
With the added weight, don't forget to increase your tire pressure, you'll find the truck handles better. I always added air to my rears to 55psi when I loaded it. It would help with the loose feeling.
