Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Tech Forums > 2011 Ford SVT Raptor Forum (Reply Only)
2011 Headlight Bulb Replacements?
This is a discussion on 2011 Headlight Bulb Replacements? within the 2011 Ford SVT Raptor Forum (Reply Only) forums, part of the Ford Raptor Tech Forums category!
I'm not looking to HID swap my front headlight assemblies... But I prefer the "whiter" look... 0n my 2009 Z06, ...
Like Tree12Likes
Old 04-19-2011, 06:08 PM   #1 (permalink)
Default 2011 Headlight Bulb Replacements?
But I prefer the "whiter" look... 0n my 2009 Z06, they do have HID's, but I replaced the bulbs with an even "whiter" bulb.... I think they were called "Sylvania Silver or White Stars"?
My point is.... other than going HID, have any of you swapped out the bulbs on your Raptor yet for something with a whiter type light? IIRC, the single bulb houses both the low beam and high beam bulb somehow...
If you replaced your bulb... do you have any before/after pics?
Brand/Part #?
Mark Ducati is offline   Reply With Quote
Old 04-19-2011, 07:42 PM   #2 (permalink)
They are called Silver Stars. Here is what fits a 2011 F150 according to Sylvania's website.
Amazon.com: Sylvania H13 ST BP TWIN SilverStar Headlight - Pack of 2: Automotive Amazon.com: Sylvania H13 ST BP TWIN SilverStar Headlight - Pack of 2: Automotive
Fordx4 is offline   Reply With Quote
Old 04-19-2011, 08:13 PM   #3 (permalink)
SilverBolt's Avatar
Hired Gun
H13 is the buld style/size. Anything beyond 5000k in color you begin to loose light output.
2012 Toyota FJ Cruiser
SilverBolt is offline   Reply With Quote
Old 05-16-2011, 10:13 PM   #4 (permalink)
Ruger's Avatar
Look here: RECON HID & Xenon Headlight Bulbs for all makes & models of car, truck, SUV & motorcycle - GET Lit w RECON Today
I got the Diamond White bulbs and am very pleased with them. They're not that obnoxious blue that blinds oncoming drivers, produce a good pattern on the ground, and are very reasonably priced.
Ruger is offline   Reply With Quote
Old 05-16-2011, 10:17 PM   #5 (permalink)
whtrapta's Avatar
Ostrich Wrangler
I swapped mine out, but it wasn't worth it. the lights were like $50 and did pretty much nothing. I just got DDM tuning hids for $70 with hi/lo and WOW what a difference.
Just when you think your done modifying... your not.
whtrapta is offline   Reply With Quote
Old 05-18-2011, 01:57 AM   #6 (permalink)
BMart's Avatar
FRF Resident Artist
you're running OEM housing right? What DDM kit and color did you go with? Pics?
Back on topic, if you're going OEM replacement for halogens, I've heard that most are just covered in tint that changes the color, but you end up losing output. I've heard that the Philips Xtreme bulbs actually do increase output for OEM replacement, but I've never tried it. If you want the real deal, it looks like Wht might have a cheap and usable solution.
BMart is offline   Reply With Quote
Old 05-18-2011, 07:46 AM   #7 (permalink)
Just checked out their website...is the install true to the directions that are given in their PDF doc?
CB17 is offline   Reply With Quote
Old 05-20-2011, 12:51 AM   #8 (permalink)
The only bulb you can put in the stock housing and really get an improvement is the Phillips Extreme H13.
The quality of the light is much better/cleaner and patterns out a lot better than the OEM bulbs.
Silverstars are a joke (as are any other "colored" tuner bulbs). Your eye perceives the color tone, but you're not actually getting more lumens or better lighting.
I'll admit, I've bought the Silverstars in the past thinking they were better. After running the Phillips I can say for sure they provide more actual light.
<b>Philips <font color="red">Xtreme Power</font> H13 / 9008 65/55W</b> (TWO PACK)
mblgjr is offline   Reply With Quote
Old 05-20-2011, 12:58 AM   #9 (permalink)
Read here. From my other research; he's accurate.
Daniel Stern Lighting Consultancy and Supply
Old 05-20-2011, 09:36 AM   #10 (permalink)
whtrapta's Avatar
Ostrich Wrangler
I ran 600k 35w bulbs. I installed the whole thing without the directions it was so easy. If you look at what you have before you start, you can figure it out. The main wire harness plugs into the passenger side h13 headlamp plug. The bulbs plug into the ballasts which plug into the wire harness. Then the wire harness is set up to run across to the other side where you plug in the other ballast and bulb. The driver side h13 is unused with this kit as it specifies it should be. The harness has to ply on the passenger side because it jade to connect go the battery for power. A couple of self tapping screw to ground into the frame and thats it
2011 Ford Mustang SVT GT500 <-- Yes I said 2011 TeamFordRaptor Garage Sale 7 07-05-2011 05:52 PM
Replacement bulb part #'s... Crosstx Ford Raptor Lighting Modifications Forum [GEN 1] 3 04-16-2011 08:01 PM
