Deaver rear springs @ SDHQ
SDHQ
GILBERT, AZ
F150 SVT Raptor Rear Spring
Benefits:
Eliminates factory block
11 leaf count of thin material
Progressive spring design
Rebound leaf to reduce axle wrap
Improves off road performance
Direct bolt on to stock location
Parts :
Leaf springs
U bolts
Bushing kit
18mm front eye bolts
We have a couple "off the shelf" choices (Deaver will make us anything specific also). We will have a +1" spring which is on the black Raptor above and then we also have a +2" spring. The +1" will gain you 1" of lift in the rear after removing the rear block (so 1" lower than stock) and the +2" spring will gain you 2" of rear lift after removing your rear block (so level with stock). Both are the same price and same plush ride quality!
In the near future we will be offering a lower bump stop mount to go onto your axle for those of you who are removing your factory block.
Here are some pics and install instructions - http://www.superduty-hq.com/RaptorRearSuspension.aspx
BOJANGLES
Chihuahuan Desert (EPTX)
Looky looky what I got delivered....
Came in on a big freight truck. This is the +2" pack.... I should get them mounted fairly soon.
Thanks SDHQ!!!!!
pirate air
will plunder your booty
^^^ I think those were supposed to come to MY house instead :)
