noise from rear of truck
I have a 2010 raptor 1500 miles and im getting a loose knocking sound from the rear end while on ruff terrain or even pulling in the drive way. Has anyone else had this problem? i can go to the rear of the truck and shack left to right and it sounds like the bed is loose or the rear end has something banging around inside of it. It is bad enough i made an oppointment at the local ford dealer to have it checked out. i shook the rear end of the one they had on their lot and its nowhere near as bad as mine. thanks guys todd
AndyR
Check to see if your spare is snugged tight. A few of us found them loose from the factory @ the Raptor Roundup.
AUH1
Abu Dhabi, UAE
I have the same problem and was told to check the vibration damper below the bed and above the spare tire. My car is at the dealer now to install the remote starter and check on this problem. Mine feels like a weight is shifting when you accelerate from a stop and there is a clear thud.
BigJ
x2 this. (Spare tire check too). Every 'clunk' I've heard of so far has been related to this dampener.
I got under the truck today and the spare was tight and that vibration dampner seems like it would only be the case if it was making the noise driving but I found that it seems to be coming from the leaf springs. Almost like they aren't tight enough against eachother and wiggling left to right along with some hub noise and differential noise. I don't know but it's frustrating brand new truck. Please elaborate more on the dampner thing and how to check it out.
MarkT
The vibration damper in question is a large steel weight mounted on a flexible hanger above the spare tire (towards the front) on the driver's side. As others have said, it is the most likely source of a clunk.
Hopefully, the dealer can figure it out if it's not.
AUH1
Abu Dhabi, UAE
My dealer was useless and showed me a bulletin from Ford saying that the shocks make noise and that it is normal. I highly doubt the noise is coming from the shocks so will try to find the vibration damper. I assume I need to remove the spare tire to get to it. right?
