Can't Take the Squeak Anymore - Pls Help!
NHDoberman
Seacoast, NH
2011 Screw with only 32K miles on it. There is a squeal on the rear driver's side wheel that is driving me nuts. Put on new rotors and pads and it's still there. Just tried new ceramic pads and same thing. It sounds as though something is rubbing against the rotor as you can hear it if you drive slow or fast as it makes the noise at the rate the wheel turns. I am at a loss as this point and it's embarrassing. Didn't find any rocks, etc.
If anyone has any suggestions on other areas/what else to check I would greatly appreciate it. Thank you, Scott.
Quartz
Denver, CO
One of my wheels had a squek because the weights on the inside of the rim were rubbing the outside of the caliper.
NHDoberman
NHDoberman
Seacoast, NH
She would be screaming at me to slow down if she was back there!
---------- Post added at 02:24 PM ---------- Previous post was at 02:22 PM ----------
Thanks guys. All good things which I will look into!
