Droid
kglesq's Brother
- Joined
- Sep 25, 2010
- Posts
- 1,483
- Reaction score
- 753
My 2011 won't start by the ignition switch with either key. Remote start works fine.
Have tried disconnecting/reconnecting battery. Swapped starter-related relays with not-very-important relays. Fuses look good. Tapping/hitting (not hard) the steering column while trying to start has no effect. I can hear the fuel pump fire when the key first touches the ignition switch (as it should). I hear/see absolutely no change when turning the key to the start position, it's as though the circuit is not being closed at all.
The Nav shows no DTCs (holding the 3 and 6 presets on the radio will put it in diagnostic mode, one of the options is to show DTCs).
Remote start thankfully works just great.
Is there any quick fix here? A specific loose connector, clean something, etc, or (more likely) is replacement of the ignition switch required? Truck is under warranty, but I'd rather spend 5 minutes fixing it than several hours of dealer BS.
Thanks for any suggestions.
