raptor rick
- Joined
- Feb 9, 2016
- Posts
- 14
- Reaction score
- 4
hey guys new to the forum and have been searching around a for the issue i am having and have found a few similar issues but resulted not being my issue.
november 16 2016 4pm - i drove the truck to around 5 miles after warm up to make a payment drove fine on the way back i was sitting at a light when it turns green i started the go normally from a green light rolled about 5ft then felt like it shifted into second then nutral then felt like i got rear ended 5times back to back then ended up in like 3rd or fourth gear.Drove a few block to get to safe spot to pull over and ther truck downshifted to firts that it locked up the wheels to slow it down turned off the truck loocked around and did not see anything unusual so fired it back up and drove 35miles home with no issues. at this time i noticed i am no longer under warranty.
november 18 2016 7am - started it up and warmed it up as i usually do drove a few blocks then again it kinda shifted but then back to netral then bang 3rd gear i belive and stayed there. got to a red light when taking off it was still in 3rd gear never down shifted so i drove back home and noticed my speedo was at 0mph but i was doing around 40mph also my gas guage said i had 1/2 tank of gas but my display read --- MILES TO E FUEL LEVEL LOW also tranny temp was normal so after i noticed this i pulled over turned off the truck and started it and everything reset and drove to work and back 70miles round trip without issues.
december 23 2016 7am driving normal got on the gas to kick down to pass a slow truck and felt like it shifted back and forth between 4th and 5th maybe 2nd at one point since it locked the back tires for a quick second after that drove find the rest of the way to work about 20miles.
sorry for long explenation just wanted to make sure i documented every detail btw no check engine or codes were stored either as that was the first thing we checked. thanks in advance
